Burnt washing machine bushes (with pics)
8 Feb 2006
Hampshire
i pulled the bushes out of the motor in my hotpoint as the drum was struggling to spin and they dont look too healthy. im unsure as to whether the dodgy looking bushes are the cause of the problem, or if they look like this because of a problem elsewhere. click on the picture for a bigger version.
thanks, kristian
just needs new brushes, that is very badly worn, make sure replacements are laminated brushes
new bushes = no change.
belt looks fine and is tensioned correctly.
removed the belt and the drum spins perfectly.
i tried a programme without any load in and it worked fine.
so i guess its the motor thats the problem.
i've removed the motor and had a look. nothing out of the ordinary but i'm not 100% on what a good one should look like. ive pulled the inner coil out and it the copper wire looks fairly sooty.
any suggestions (apart from buy a new one ;))
Is it possible you may have forgot to release the spring loaded carbon brushes before fitting them to motor. This must be done by bending the small brass strip towards you,and this is done by inserting a small screwdriver blade and bending the strip towards you. I am very surprised after seing photo of your brush condition that this has not cured the problem.
hi, the springs are definitely released (they showed me how to do it in the shop). best way to describe problem is that the drum looks like its trying to pull away in second or third gear. once it gets going its fine, its just the initial struggle. ive played with it some more but i've almost resigned myself to a new machine.
Breezer
How does that connector look to you?
It looks fairly well damaged (by sparking from the com ?) to me
I would be tempted to change these/clean the com or fit new motor before buying a new machine
a few people have suggested motor and armature. i'm reluctant to throw money at it though. i spent £17 on bushes- i dont really want to spend much more if im not 100% it'll fix the problem. i see buying a new one as the lesser of two evils :)
