DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hot fuse - fishy smell !!
Author Message
emanresu
from United Kingdom
PostPosted: Wed Feb 08, 2006 11:32 pm Reply with quote
Having dinner at my in-laws a while back, I smelt fish, which wasn't on the menu! Smelt (no pun intended) it again recently and traced it to their fuse box, which is in the same room. The "fishy" smell was actually coming from the casing of the fuse cartridge melting. icon_surprised.gif
Having turned of the electricity, I needed oven gloves to remove the fuse as it was so hot. It was also looking a bit worse for wear so I replaced it with a spare cartidge. BTW, this was the 30A fuse for the downstairs ring main. Noticed this fuse soon got hot as well. Investigation shows this happens when the washing machine and (brand new) dryer are on together. If either are on separately then the fuse case is cool to the touch.
Obvious answer is not to run both together, but sometimes that is difficult. Are there any dangers in replacing the fuse with a 45A unit? icon_question.gif
Thanks for your help...
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 154 times
PostPosted: Wed Feb 08, 2006 11:37 pm Reply with quote
You should ensure that the fuse carrier is clean and making good contact with the fuse, that the legs of the carrier and the clips in the board are clean and making good contact with each over, and the outgoing circuit cables are tightly terminated in the top of the fuse way
I'm assuming a wylex standard board, is this correct?
http://www.tlc-direct.co.uk/Images/Products/size_2/WY304.JPG
(they were also produced in brown)
Edit: with a BS1361 in carrier fitted:
http://www.tlc-direct.co.uk/Images/Products/size_2/WYC30.JPG
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 154 times
PostPosted: Wed Feb 08, 2006 11:41 pm Reply with quote
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Thu Feb 09, 2006 12:06 am Reply with quote
Once when we had a Wylex standard, my dad was working on the shower circuit upstairs and I saw a flash come from under the steps. Turned out the MCB had jumped out of its socket. icon_eek.gif Cant remember how, now, i was only a kid.
emanresu, they dont have the immersion heater on the downstairs ring too do they? And cooking dinner - was the toaster / kettle on?
But as Adam said, check all the connections, and recommend they have a new modern CU fitted - there may now be a problem with the springiness of the metal sockets of the fuse holders (especially with getting very hot as you describe - and the fuse is therefore not making proper contact.
Back to top
 Alert Moderators
Jaymack
from United Kingdom
Thanked: 3 times
PostPosted: Thu Feb 09, 2006 11:19 pm Reply with quote
The fishy smell is a characteristic of burnt bakelite, commonly used before the introduction of thermoplastics for electrical equipment.
Back to top
 Alert Moderators
emanresu
from United Kingdom
PostPosted: Fri Feb 10, 2006 12:01 am Reply with quote
All very helpful/informative.
I'll check it out on Sunday, hope to post back early next week.
Cheers....
Back to top
 Alert Moderators
emanresu
from United Kingdom
PostPosted: Mon Feb 13, 2006 8:00 pm Reply with quote
Checked out the board, it is a Wylex 804 IVY.
Hard to see why that fuse alone is having problems; noticed it getting hot in general use, not just when the washing is being done. Clips could possibly be loose, hard to tell once it is pushed in! Didn't think to clean them though.
Anyway, have advised them to get in qualified electrician and that he'll probably replace the CU.
Thanks.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Shower fuse and fishy smell! 9 400 Sat Feb 26, 2011 6:05 pm
Fishy smell from shower switch. Advice needed!!!! 4 2380 Mon Jun 23, 2008 4:48 pm
Fishy Smell in House 3 2020 Thu Sep 29, 2011 10:43 am
Fishy smell 3 860 Tue Dec 11, 2007 1:53 pm
[b]fishy smell when using shower[/b] 8 12600 Tue Feb 28, 2006 5:56 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
