DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
15 amp fuse overload
This topic originated from the How to page called Changing a fuse on the consumer unit
Click here to return to the page called Changing a fuse on the consumer unit.
  View previous topic :: View next topic
Author Message
andy robo
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 10, 2006 9:12 pm    Post Subject:
Reply with quote Thanks
hi, I have got a problem with a blue 15 amp fuse which keeps on blowing all the time when i put on two or more appliances together. Does anyone know if this is right. Seems to me this is a ring circuit. :D
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 10, 2006 9:27 pm    Post Subject:
Re: 15 amp fuse overload
andy robo wrote:
hi, I have got a problem with a blue 15 amp fuse which keeps on blowing all the time when i put on two or more appliances together. Does anyone know if this is right. Seems to me this is a ring circuit. icon_biggrin.gif
sure its a ring? rings are normally 30A. it might be a radial. unless your 100% its a ring, and wired in 2.5, DONT change the fuse to 30A (chances are its a radial tho)
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sat Feb 11, 2006 11:29 am    Post Subject:
If it is a radial, wired in 2.5mm˛, the fuse is doing its job. Though the fact you have a 15A radial on an old fuse would tell me its time for a PIR (periodic inspection), to check for other problems you may have (old wiring, bits and bats added on over the years).
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Feb 11, 2006 12:22 pm    Post Subject:
doesnt matter if its a ring or not, 15a fuse is blowing becuse you are using too much current.
if your wiring is old it sounds like time for a rewire to accomodate your new demand, and no you cant change the fuse to a bigger one
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Overload 4 760 Thu Oct 06, 2005 6:13 am
C U overload query 11 580 Sat Mar 10, 2007 4:46 pm
Will shower overload rcd? 6 460 Thu Aug 11, 2005 1:04 pm
Overload protection 8 740 Wed Jul 27, 2005 7:49 am
Overload - time for sparky? 3 3760 Tue Mar 30, 2004 4:17 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
