johna106
Joined: 07 Jan 2005 Posts: 12 Location: United Kingdom Thanked: 0 times
Posted: Fri Feb 10, 2006 11:24 pm Post Subject: Hot Water Flow |
Just installed a new bath, hot water flow ain\\\'t great...
Is there any way of increasing the pressure from the hot water cylinder to the taps?? |
Agile
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 191 times
Posted: Fri Feb 10, 2006 11:44 pm Post Subject: |
Yes, a ( shower ) booster pump!
Tony |
ChrisR
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Sat Feb 11, 2006 1:04 am Post Subject: |
Maybe you bought taps designed for hi press hw and yours is supplied from cw tank in loft through a cylinder, ie low pressure. ?? |
Prof.plumb
Joined: 09 Feb 2006 Posts: 188 Location: Leicester, United Kingdom Thanked: 2 times
Posted: Sat Feb 11, 2006 10:16 am Post Subject: |
Nope i know what your problem is. You fitted you own bathroom and i bet you used flexi hoses. The cold will be ok as it is under mains pressure. HOwever, the hot is more than likely under gravity pressure.
In short rip out the flexi and put some 15mm copper in place. |
JOPLUMB
Joined: 11 Feb 2006 Posts: 7 Location: Cardiff, United Kingdom Thanked: 0 times
Posted: Sat Feb 11, 2006 12:30 pm Post Subject: hot water pressure |
________________________
lynda, moderator
please note forum rule 20 |
