Joined: 11 Feb 2006 Posts: 7 Location: Cardiff, United Kingdom Thanked: 0 times
Posted: Sat Feb 11, 2006 12:43 pm Post Subject:
hot water flow
installed a bath on a like for like basis, using existing 22mm copper (on an older style house).Hot water is fed from a combi in cupboard next to bathroom. hot flow is poor...would changing a section of 22mm to 15mm upto tap make for better pressure???
Joined: 06 Jun 2004 Posts: 1642 Location: London, United Kingdom Thanked: 0 times
Posted: Sat Feb 11, 2006 4:59 pm Post Subject:
Why would making a pipe SMALLER improve the flow???? Bigger pipes = less resistance = more flow.
Or do you mean that the water flow is OK but not hot enough (= boiler not man enough).
Or water takes a long time to get hot (MIGHT be due to large static volume in 22 mm pipes but unlikely to be significant).
Or do you mean something else entirely?
Posted: Sat Feb 11, 2006 6:40 pm Post Subject:
no prob with temperature , just thought the combi would give a good flow..( very old brown baxi combi )
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
Posted: Sat Feb 11, 2006 7:13 pm Post Subject:
Re: hot water flow
No. It wouldn't.
In any case you don't need to change the pressure, you need to increase the flow. However, you might not be able to.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
