DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
oil based paint
This topic originated from the How to page called Using the correct sealer and primer
Click here to return to the page called Using the correct sealer and primer.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
Elaine Smith
from United States of America
Thanked: 0 times
PostPosted: Tue Feb 14, 2006 11:33 pm    Post Subject:
oil based paint
Reply with quote Thanks
my brother in law used oil based canvas paints to decorate a room in his home. How can we either remove or cover it so we can repaint? (it looks horrible)
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Nestor_Kelebay
from Canada
Thanked: 0 times
PostPosted: Wed Feb 15, 2006 12:57 am    Post Subject:
If the oil based paint is glossier than a satin gloss, then:
Either you need to roughen it somehow so that any subsequent paint will stick well to it, and this can be done by sanding it or using a chemical deglosser like "Liquid Sandpaper".
Or, you can use a super sticky primer like Zinsser's Bullseye 123 water based primer which is sticky enough to stick well to even smooth surfaces.
If the oil based paint is a satin or flatter, then you can get away with just painting another oil based paint over top of it.
If you want to paint with a latex paint, then I'd suggest you use an oil based primer over the oil based paint, and then paint over the oil based primer with your latex paint.
You can also paint over Zinsser's Bullseye 123 with a latex paint as well.
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 3 times
PostPosted: Wed Feb 15, 2006 8:45 pm    Post Subject:
Elaine...whats canvas paint?...we dont have that here..Nester may be able to help you out here hes from Canada
__________________
How much!
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 0 times
PostPosted: Wed Feb 15, 2006 9:58 pm    Post Subject:
Zampa:
We don't use the term "canvas paint" here either. I'm presuming what she meant was an artist's oil based paint (as opposed to a house paint) that would normally be applied to a piece of canvas (as opposed to being applied to a wall).
But, artist's oil based paints still use drying oils like walnut oil and poppyseed oil as the binder, and that means that chemically, they're ver similar to the old linseed oil based paints that were commonly used for house paints until recently. Basically, regardless of whether the paint is made from walnut oil, or poppyseed oil or linseed oil or alkyd resins (which are best considered clumps of soy bean oil fragments), the chemistry of the film is very similar. They all consist of a film made of vegetable oil molecules (or parts thereof) all connected to one another with pairs of oxygen atoms (called "crosslinks").
That is, I see no reason why an artist's oil based paint shouldn't be treated the same as an oil based house paint when it comes to deciding how to paint over it.
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 3 times
PostPosted: Thu Feb 16, 2006 8:27 pm    Post Subject:
Cheers for that Nessy...it didnt occur to me about artist colours..expensive way of buying paint though.
__________________
How much!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Radiator paint: water based or traditional? 5 820 Tue Feb 20, 2007 8:50 pm
how to paint? with (oil based) gloss 8 760 Thu Dec 14, 2006 9:48 am
Storing wet oiled based paint brushes - water or BrushMate? 15 1260 Thu Nov 23, 2006 9:38 am
water based masonry paint over pliolite masonry? 2 960 Sat Jun 14, 2008 8:31 pm
Water based paint for radiator 2 240 Fri Jun 20, 2008 5:34 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
