DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Spurs
This topic originated from the How to page called Miniature circuit breakers (MCBs)
Click here to return to the page called Miniature circuit breakers (MCBs).
  View previous topic :: View next topic
Author Message
Granville000
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 17, 2006 9:56 am    Post Subject:
Spurs
Reply with quote Thanks
Can I install a small lighting cct for a dining room by tapping off the ringmain through a (5A) fused spur?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
royster
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 17, 2006 10:32 am    Post Subject:
CCT?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Feb 17, 2006 11:01 am    Post Subject:
Circuit!
Yes. But you are right, it must be limited to 5A so the spur needs to be visibly marked to show what it is, and that it needs a 5A (no more) cartridge.
Probably a good idea to amend the label on the CU as well, from "32A Ground Floor Sockers" to "32A Ground floor sockets (includes 5A spur dining room rights)"
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Fri Feb 17, 2006 4:41 pm    Post Subject:
Back to top
 Alert Moderators
Granville000
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 17, 2006 5:30 pm    Post Subject:
Spur
Thanks, I will mark the spur.
As a matter of interest, has there ever been an mcb designed to plug into the old CUs to replace the wired fuse plug? I have a big house and all the original CUs (4) have wired fuses and, being under some stairs, are a s** to get at. Do you know of a midget electrician? icon_lol.gif
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri Feb 17, 2006 5:37 pm    Post Subject:
if its a wylex standard then the breakers are easy to get. anything else and it gets tricky or impossible.
be warned though that breakers tend to neusense trip on lighting cuircuits a LOT more than fuses do!
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Feb 17, 2006 6:54 pm    Post Subject:
If the CU looks like this (may be brown, or grey if metalclad)
Then you can get plug-in MCBs (you have to change the plastic base that comes with them as it is not quite the same size as the same-coloured plastic base on the rewirable fuse). You can see they have brass prongs like the old fuseholder.
They may cost £7 each at Screwfix, but there are dozens on Fleabay every week from people who have just replaced their old Wylex box. The push-button MCBs are the 1970's version, the flick-switch are current. Both fit.
Wylex also make a retrofit 30A/30mA RCD kit accessory (catalogue ref WRF) which sounds very handy, but I have never seen one used.
(Agree with plugwash about nuisance tripping - every time a kitchen spotlight burns out, the MCB pops. None of my other lighting circuits do it as they don't have spotlights.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Spurs 2 240 Fri Dec 14, 2007 9:35 pm
Ring main and spurs 4 500 Tue Dec 04, 2007 11:08 pm
sockets are all spurs!!? 5 500 Sun Dec 02, 2007 1:16 am
Can fused spurs be put in series 10 640 Sat Nov 03, 2007 7:09 am
Switched spurs for the gamesroom 4 200 Tue Feb 05, 2008 12:18 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
