DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
biro on carpet
This topic originated from the How to page called Ballpoint Pens
Click here to return to the page called Ballpoint Pens.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
minesweeper
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 17, 2006 10:16 am    Post Subject:
biro on carpet
Reply with quote Thanks
how do i get biro stains from a carpet? help
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
kima2904
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 17, 2006 10:56 am    Post Subject:
This might not work but this is what i'd try if it happened to me (successfully mopped up huge puddle of red wine once from a white carpet!)....
Get a little bottle of sodawater pour all over it, let it soak in for a couple of minutes and then just put a newspaper on it and something quite heavy like books (you don't want) to weigh the newspaper down, it should soak the stain right up with no need to scrub.
In a couple of hours when you lift the newspaper it should be completely dry too.
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 0 times
PostPosted: Fri Feb 17, 2006 3:09 pm    Post Subject:
Minesweeper:
Do the following:
1. If you don't have one, go and buy a shop style wet/dry vaccuum cleaner.
2. Phone your local carpet cleaning contractors and find out which of the places listed in your phone directory under "Janitorial Equipment & Supplies" have staff that are more knowledgeable about carpet cleaning.
3. Go to that (or those) places and ask to buy a "spotting solution" (the term might vary from country to country) for removing biro from a carpet.
You see, the companies that make the carpet detergents, enzymes, defoamers and acid rinses that professional carpet cleaning contractors use to clean carpets with will also offer a line of stain removers. Typically, they will market these stain removers as a kit containing anywhere from 8 to 18 different chemicals for removing different kinds of stains from carpet and upholstery. However, they also will sell these cleaners individually because if a contractor runs out of one, he doesn't want to buy a whole kit of 18 just to get more of the one he needs.
Those Janitorial Supply places typically sell to contractors, but they will also sell to you if you pay cash. The reason why is that there's no such thing as a Janitorial Supply retail store that they also sell to who'll bark at them for stealing their retail business. The closest thing to that are the grocery and hardware stores, and those places don't buy from the local Janitorial Supply outlets anyhow.
Tell the guy at the place you buy the biro cleaner from that you have a wet/dry vaccuum cleaner and intend to use that as a poor man's carpet "extractor" or "shampoo'er" by just pressing the suction end of the vaccuum hose directly onto the carpet pile. (He'll realize that's a good idea for someone wanting to remove a stain from a carpet).
Follow the directions on the bottle. Most likely you'll just apply the cleaning solution to the carpet, work it in, allow time for it to work, and then suck the soiled cleaning solution out with the wet/dry vaccuum cleaner. Repeat as necessary. Then, do an encore performance using clean rinse water.
And, the above advice also applies for any other kind of a stain as well. You can get "spotting solutions" (which is what they're called here) to remove ink and toner, coffee and tea, blood, feces, urine, vomit, you name it. And, with a cheap wet/dry vaccuum cleaner, you can use the same cleaners the professional carpet cleaners in your area use to remove stains as well as they could. Certainly it would be cumbersome to shampoo an entire carpet with a wet/dry vaccuum cleaner, but you can certainly use a wet/dry vaccuum cleaner and professional cleaning products to remove stains from it. Ditto for upholstery.
PS:
I think the only reason why more people don't buy their cleaning supplies from janitorial supply outlets is because they're simply not aware that by doing so the will come into contact with people that are highly knowledgeable about cleaning willing to give out free advice on cleaning in those places.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
biro on lino 4 1680 Tue Mar 14, 2006 12:57 pm
Biro on fridge door 2 2540 Mon Aug 21, 2006 12:35 pm
Ball point pen (biro) marks on laptop cover 3 340 Sat Apr 18, 2009 12:26 pm
HOW TO REMOVE BIRO FROM LEATHER CHAIR 2 1840 Sun Dec 29, 2002 5:32 pm
Biro stain off uniform 2 960 Mon Jan 30, 2006 9:54 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
