Indesit WD125
ja1
17 Feb 2006
Dryer part faulty. Found fan not running, now running OK, but no heat. Any ideas? Is there a pressure switch or sensor somewhere which detects fan running, or is new fan required?
Check the heater elements and thermostats. Also check to see if there's a cable runs across the heater box under a clamp, if there is, check this for continuity as it's a thermal fuse.
Unplug your appliance before working on it.
Thanks...any guidance on exactly how to locate the elements/thermostat/heater box??
