DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
acrylic paint
This topic originated from the How to page called Acrylic Paint
Click here to return to the page called Acrylic Paint.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
jabarca
from United States of America
Thanked: 0 times
PostPosted: Sat Feb 18, 2006 9:10 pm    Post Subject:
acrylic paint
Reply with quote Thanks
My son got acrylic paints on our stained wood dining room table. how do i get it off with out stripping the stain?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Nestor_Kelebay
from Canada
Thanked: 0 times
PostPosted: Sat Feb 18, 2006 10:13 pm    Post Subject:
Unfortunately, all of the chemical strippers I'm aware of will attack both acrylic and oil based finishes. If dulling the gloss of the oil based finish on the table wasn't a problem, then you could remove the acrylic paint with nail polish remover. But that would also leave a dull spot on the glossy dining room table where the oil based finish has been roughened.
If push comes to shove, you can always use nail polish remover and then restore the gloss by painting highly thinne polyurethane on the dull spot, but it's probably worthwhile to try another method first:
Oil based finishes like polyurethane are much harder than acrylic water based finishes, AND oil based finishes won't soften in the presence of moisture like acrylic finishes are more prone to do. So, what I would do is dampen the acrylic paint with warm soapy water and allow that water a few minutes to soften the acrylic paint. Now take something harder than the acrylic, but softer than the oil based finish (like a wooden popsicle stick or plastic cuttlery knife) and try scraping off the acrylic paint. Hopefully, if the moisture softens the acrylic paint sufficiently, you might even be able to scrape it off with a fingernail.
SOME furniture is finished with lacquer which will turn clowdy if you leave water or a wet rag on it's surface. However, I don't believe anyone would use a lacquer finish on a dining room table which would be expected to have to endure the occasional water spill or wet place mat on it.
You can also remove the acrylic paint with any strong solvent, and ordinary nail polish remover will remove the acrylic paint much more aggressively than the oil based finish. It will, however, remove some of that oil based finish, and the result may be a dull spot on the dining room table. However, you can restore the gloss in that spot by thinning one part varnish or polyurethane with two parts white spirits (aka: paint thinner) and painting that over the dull spot. When it's thinned that much, it will self level by itself and dry to a very flat surface. However, it might still have to be polished for the surface to match the gloss on the rest of the table.
Try softening the acrylic paint with warm soapy water and scraping off the acrylic paint, and let us know how well that worked.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Acrylic shower tray - urgent 6 600 Mon Mar 03, 2008 9:39 am
Re coating Acrylic bath 7 380 Thu Oct 08, 2009 8:36 am
Milling acrylic 4 840 Mon Jan 06, 2003 12:35 am
Chipped acrylic (or fibreglass) bath HELP! 5 1320 Mon Feb 25, 2008 10:46 pm
Strengthening an Acrylic bath panel 2 280 Sat Jan 10, 2009 10:28 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
