DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
earth cross bonding in bathrooms & kitchens
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
Lextoy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 19, 2006 11:36 am    Post Subject:
Reply with quote Thanks
Does anybody know the regs? I have been told that all light fittings in bathrooms and kitchens should be cross bonded. Is this correct when a light fitting is double insulated
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
baldelectrician
from United Kingdom
Thanked: 3 times
PostPosted: Sun Feb 19, 2006 11:49 am    Post Subject:
no additional bonding is required in a standard kitchen (ie one without electric waste disposals and similar items)
Bathroom bonding is required and important.
Search on the forum for the spefics
Back to top
 Alert Moderators
Lextoy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 19, 2006 12:12 pm    Post Subject:
Thanks. I am well aware that the metal items have to be cross bonded within the bathroom. My specific question was: do all light fittings have to be cross bonded even though they are double insulated?
Back to top
 Alert Moderators
Har_vey
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 19, 2006 12:23 pm    Post Subject:
The lighting circuit coming into the bathroom has to be bonded to any other electrical circuit in the bathroom. So it's not just a case of ignoring it if the fitting happens to be double insulated. You obviously don't bond to a fitting which is double insulated, but someone might change the fitting at some point.
Back to top
 Alert Moderators
Lextoy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 19, 2006 12:33 pm    Post Subject:
On this occasion I am installing GU10 recessed double insulated spot lights. These fittings have no terminal for connecting an earth wire to them. As far as I am aware the regulations for double insulated light fittings state that no earth wire must be fitted. So what now happens with cross bonding these lights in bathrooms? Should I now go against the regulation and connect an earth wire when in fact it says I shouldn't. This installation will have to be certified on completion.
Back to top
 Alert Moderators
Har_vey
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 19, 2006 12:43 pm    Post Subject:
presumably if they don't have to be earthed due to being double insualted, then you just make sure that the lighting circuit itself is covered. Then you just have to watch that the lights are ok to be positioned in the bathroom re the zones?
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun Feb 19, 2006 1:24 pm    Post Subject:
Re: earth cross bonding in bathrooms & kitchens
1) It's not as simple as all metal items - you should only apply supplementary equipotential bonding to extraneous-conductive-parts, not simply anything metal. This is crucial, as bonding something which is not an e-c-p makes things less safe, not more.
2) It's the cpcs of circuits supplying appliances that are bonded, not the appliances themselves (although with Class I appliances the earth terminal may be a convenient place to access the cpc). If you've got Class II luminaires then you'll need to find somewhere else to connect to the lighting cpc.
3) It isn't only lighting circuits that are involved.
Regulation 601-04-01:
Local supplementary equipotential bonding complying with Regulation 547-03 shall be provided connecting together the terminal of the protective conductor of each circuit supplying Class I and Class II equipment in zones 1, 2 or 3, and extraneous-conductive-parts in these zones including the following:
(i) metallic pipes supplying services and metallic waste pipes (eg water, gas)
(ii) metallic central heating pipes and air conditioning systems
(iii) accessible metallic structural parts of the building; (metallic door architraves, window frames and similar parts are not considered to be extraneous-conductive-parts unless they are connected to metallic structural parts of the building)
(iv) metallic baths and metallic shower basins.
The supplementary bonding may be provided in close proximity to the location
See the following for useful information:
Bathrooms
Definition of "extraneous-conductive-part"
Earthing v bonding
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
wiring appliances in kitchens 16 1200 Fri Apr 20, 2007 9:37 am
zoning in kitchens 4 380 Sun Nov 20, 2005 5:37 pm
part p and kitchens 7 640 Thu May 05, 2005 4:05 pm
Cables in kitchens 19 880 Mon Jul 02, 2007 10:37 pm
MCB and kitchens 3 2140 Sun Mar 27, 2005 7:00 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
