DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Difficulty starting Transit in cold weather
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
gcol
from United Kingdom
Thanked: 52 times
PostPosted: Sun Feb 19, 2006 2:55 pm Reply with quote
I have a Transit 2.5 DI (1999) that proves difficult to start in the mornings when the temperature is around 0C and nigh on impossible at -3C or less. This model doesn't have glow plugs and I've changed the battery already. Once it's been started, it'll start easily all day long.
There's a cold starting aid mentioned in the owners manual, but I don't know what that does, or if it can become faulty.
Any ideas folks?
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 2 times
PostPosted: Sun Feb 19, 2006 5:42 pm Reply with quote
electric blanket?
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 52 times
PostPosted: Sun Feb 19, 2006 7:06 pm Reply with quote
Thanks for that Andy, have you any other ideas cause I don't think that an electric blanket is the proper solution?
Regards,
Back to top
 Alert Moderators
johnwr
from United Kingdom
PostPosted: Sun Feb 19, 2006 7:44 pm Reply with quote
Transit diesels can have injection pump problems, this causes bad starting, but it usually bad starting any time, and gets worse until it fails to starts. Have you checked the compression pressures.
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 52 times
PostPosted: Sun Feb 19, 2006 10:46 pm Reply with quote
No I haven't checked the compression pressure. I wouldn't know where to start. icon_biggrin.gif
Whatever it is it's definitely linked to temperature though.
Back to top
 Alert Moderators
noodlz
from United Kingdom
PostPosted: Mon Feb 20, 2006 1:23 am Reply with quote
Haven't got a clue either gcol, but if no luck here could try posting here:
http://carcareclinic.com/WelcomeCarCareClinic.asp
Back to top
 Alert Moderators
darude
from United Kingdom
PostPosted: Mon Feb 20, 2006 10:27 pm Reply with quote
For Diesel combustion to work temperature is required (reason why Diesels have glow plugs is to help them start). I'm suprised it doesn't have glow plugs, although the cold starting aid must be something similar (IE warm the cylinders to aid combustion). I'd look into that a bit more.
otherwise I think an electric blanket is called for!!!
Back to top
 Alert Moderators
johnwr
from United Kingdom
PostPosted: Tue Feb 21, 2006 8:31 am Reply with quote
Darude, Transit 2.5L diesel engines are direct injection and do not need any heater plugs. They usually start up very quickly, so there must be either a fuel problem (injection pump) or lack of compression.
regards johnwr
Back to top
 Alert Moderators
chrispfay
from United Kingdom
PostPosted: Tue Feb 21, 2006 10:44 am Reply with quote
there is a cold start on the side of the pump which is electricaly operated and they do tend to pack up on older models, I have jammed it open to start up then removed it for normal running
good luck
munch
Back to top
 Alert Moderators
ratm
from United Kingdom
PostPosted: Sun Mar 05, 2006 8:38 pm Reply with quote
Sorry this is a bit late but I've only just found the topic. This sounds to me like water in the fuel lines or filter. If it was drawing air or had a compression problem the fault would be there all the time. The fact that it only appears to be happening when the temprature is below freezing is a dead givaway. Try adding Whynns dry fuel and see if that helps.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
fronty 2.3 diesel has difficulty starting when cold 3 460 Thu Feb 22, 2007 7:17 pm
Fiat Scudo Not starting in cold weather 6 4340 Thu Jan 12, 2006 9:06 am
Kia Pride starting problems in wet weather. 21 1320 Sat Oct 11, 2008 11:48 am
My escort van has running problems in the wet weather!!!!!!! 6 620 Mon May 26, 2008 10:11 pm
Transit wont start on cold mornings 5 680 Wed Jan 23, 2013 5:55 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
