DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
dimmer switch
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  View previous topic :: View next topic
Author Message
katem
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 19, 2006 3:30 pm    Post Subject:
dimmer switch
Reply with quote Thanks
Hi, I\\\'ve read through previous postings but am still not sure how not to blow house up. Am replacing standard single light switch with a dimmer. Didn\\\'t note which wire went where on old switch because I assumed new one would have ok instructions - it doesn\\\'t have ANY other than connect mains supply to L1 and Lamp transformer (LV) to ~. Existing socket has one thin brown wire which is connected to metal socket box (earth I assume) it then has one red and one black (must be live and neutral). So could someone just confirm if the red or the black wire connects to L1/mains supply (and the other to the ~) - this is probably a stupid query, but I\\\'m just not sure enough!! Thank you
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Har_vey
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 19, 2006 3:55 pm    Post Subject:
Normally red to L, and black (switched live) to the other terminal.
careful when you put the dimmer back because they are deeper than a standard switch so sometimes the metal box has to be recessed further into the wall.
Back to top
 Alert Moderators
katem
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 19, 2006 4:23 pm    Post Subject:
thank you! that seems to work, and no house fire yet
Back to top
 Alert Moderators
Har_vey
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 19, 2006 4:34 pm    Post Subject:
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun Feb 19, 2006 11:48 pm    Post Subject:
Re: dimmer switch
Earth wires should have green & yellow sleeving. Do you mean brown, or do you mean bare copper?
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon Feb 20, 2006 8:05 am    Post Subject:
If brown, it should be replaced with g/y sleeve.
You've obviously fitted the dimmer now, but for future reference for others, sometimes (if the box has 4 lugs), you need to remove or bend back the two in the vertical plane to allow the dimmer body to fit.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
accidentally disconnected dimmer switch from wall 3 1400 Thu Jun 28, 2007 7:07 pm
installed a dimmer switch, but bulb blowing . . 15 700 Mon Jul 02, 2007 9:15 am
Dimmer Switch problem - 3 Wires and only two connectors 8 720 Thu Jun 28, 2007 6:30 pm
Dimmer switch to heated towel rail 9 2020 Sun Jun 10, 2007 11:46 pm
Wiring double dimmer switch into new line from CU 4 2880 Thu Jun 07, 2007 9:48 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
