Joined: 19 Feb 2006 Posts: 6 Location: Surrey, United Kingdom Thanked: 0 times
Posted: Sun Feb 19, 2006 5:28 pm Post Subject:
Cable for Shed
Currently I have a shed that is fed from a fused spur from the kitchen. The supply to the kitchen is RCD protected. The cable that runs out to the shed is 2.5mm T&E. The fused is a 13A.
The cable is clipped along a treated wooden batten about 3ft from the ground fastened to shed posts.
I realise that the wiring in the shed requires attention as there should be a seperate fuse for the light to protect that circuit.
The main equipment used in the shed is a chest freezer.
My question is what cable shoudl be used- is 2.5mm T&E OK for this? I assume it should not be run unprotected (as it is now). Is 2.5 mm T&E Ok if run in plastic conduit clipped to the batten along fence posts?
Or do I *have* to use armoured cable run underground?
Joined: 14 Sep 2004 Posts: 3972 Location: United Kingdom Thanked: 0 times
Posted: Sun Feb 19, 2006 5:31 pm Post Subject:
Re: Cable for Shed
not much wrong apart from the cable
you could clip SWA to this
best use SWA feeding a mini CU with isolator (or RCD if you want, but you said its already RCD protected) and a B6 (lights) and B16 (sockets)
T&E is extremely dangerous. its not designed for outside use. use 2.5mm SWA
use SWA and do the job properly and safely. best underground, but you could clip it to a fence
Regards
Clive
Joined: 17 Jun 2004 Posts: 4539 Location: United Kingdom Thanked: 10 times
Posted: Sun Feb 19, 2006 7:49 pm Post Subject:
If you want to avoid SWA, you'd have to go for galvonised, as opposed to PVC conduit, SWA will be the easiest option of the two by far
And cables shouldn't really be run along a temporary structucture, if your fence is just a few wooden posts and some wooden panels, I'd class it as such, but if it was a concrete posted fence with gravel boards at the bottom, then I can't see too much wrong with clipping it to those
Posted: Sun Feb 19, 2006 8:12 pm Post Subject:
Thanks Adam. I'll go with SWA then. I assume that SWA shoudl also be used to connect to an outdoor halogen light....
The fence is question is exactly as you describe - concrete posts with gravel boards. The batten is screwed to these posts not the wooden fence panels.
Posted: Mon Feb 20, 2006 10:00 pm Post Subject:
ccarmock wrote:
Hi Andy,
Yes the outdoor light is fixed to the house int he back garden, via an MK IP55 rated outdoor switch.
The current cable is 1.5mm T&E. This is fed from a fused spur indoors with a 5A fuse.
Clive
use a cable thats at least wether resistant. SWA would be good, but could be a bad idea in this case. also, make sure the cables go in from the bottom, making a 'drip loop'
Posted: Mon Feb 20, 2006 10:25 pm Post Subject:
1.5mm SWA isnt too hard to work with, and apart from the glands, just as easy. depending on the terminal box at the light tho, there may not be room for an armoured gland. (there might be, but i havent seen the light)
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
