alanbazeley
Joined: 19 Feb 2006 Posts: 2 Location: Somerset, United Kingdom Thanked: 0 times
brumylad
Joined: 06 Oct 2004 Posts: 830 Location: United Kingdom Thanked: 1 time
Posted: Sun Feb 19, 2006 11:55 pm Post Subject: |
the joint between the rad extension and old valve needs boss white or PTFE tape, as does the threaded joint between the extension and the rad.
Which joint exactly is it leaking from? |
alanbazeley
Posted: Mon Feb 20, 2006 8:05 pm Post Subject: radiators |
Thanks for the reply. Leak is between the stopvalve and the extension piece. Have tried boss white and LOADS of PTFE tape. Should there be an "O" ring as well as an olive between the two? |
hotncold
Joined: 28 Feb 2005 Posts: 82 Location: United Kingdom Thanked: 0 times
Posted: Tue Feb 21, 2006 1:54 pm Post Subject: |
try Oyster extendable rad valve tails 28-54mm, they inclue O rings, available from B&Q |
brumylad
Posted: Tue Feb 21, 2006 10:01 pm Post Subject: |
put plenty of PTFE tape on the olive and not the threads |
