DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Keeping Blowing Fuses!
This topic originated from the How to page called Changing a fuse on the consumer unit
Click here to return to the page called Changing a fuse on the consumer unit.
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK
  View previous topic :: View next topic
Author Message
spcghst5
from United States of America
Thanked: 0 times
PostPosted: Tue Feb 21, 2006 2:54 am    Post Subject:
Reply with quote Thanks
The ceiling light in my bedroom had not been working for awhile so I decided to change the light switch and the ceiling light. However, after installing them fuses continually were blowing (still use screw fuses). I unwired everything and just capped off the wires and made sure nothing was touching but fuses keep blowing or they are screwed in but there is no voltage coming through, as I tested with the voltage detector. What could the problem be?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Feb 21, 2006 5:47 pm    Post Subject:
You might have connected the ceiling fitment, or the switch, or both, incorrectly.
Since cable colours and wiring conventions are going to be different, our "for reference" section might not help you much.
Sometimes the colours used in a switched light do not mean what that colour usually means.
Back to top
 Alert Moderators
swelec
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 21, 2006 6:12 pm    Post Subject:
when you put up the new switch or (more likely) the new fitting did you use fixing screws ? These could have been screwed into the cable feeding the switch or light fitting hence blown fuses
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK All times are GMT
Page 1 of 1
Jump to:
Hob fuses? 5 2120 Sun Dec 03, 2006 2:41 pm
germany - fuses or not 2 840 Wed Feb 11, 2004 12:39 pm
Electric shower, keeps blowing switch 7 1080 Tue Dec 23, 2008 9:54 pm
blowing bulbs 22 3220 Sat May 20, 2006 12:38 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
