DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Hair dye- vinyl flooring
This topic originated from the How to page called Hair Dye
Click here to return to the page called Hair Dye.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
Guest
Thanked: 0 times
PostPosted: Wed Feb 13, 2002 9:41 pm    Post Subject:
Is there anyway to remove hair dye from vinyl flooring? I've tried several methods with no luck. It has "faded" the dye but not removed it.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Thanked: 0 times
PostPosted: Fri Feb 15, 2002 3:16 pm    Post Subject:
Re: Hair dye- vinyl flooring
It might be worth trying a cloth with some diluted bleach and dab away on the surface. A scourer might scratch the surface, but a strong rubbing with a bleached cloth might help a little - good luck.
Back to top
 Alert Moderators
Guest
Thanked: 0 times
PostPosted: Mon Sep 02, 2002 8:50 am    Post Subject:
Spray hairspray on the spot and let sit a minute or so before removing. I also used steel wool because a small dull patch beats a red patch on white vinyl
Back to top
 Alert Moderators
tingilia
from United States of America
Thanked: 0 times
PostPosted: Wed Sep 15, 2004 11:19 pm    Post Subject:
hair dye on linoleum
Reply with quote Thanks
The best way to remove hairdye from linoleum is to use acetone.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Vinyl Flooring over Chipboard 8 2060 Wed May 07, 2003 3:28 pm
Removing vinyl flooring adhesive 2 940 Sun Sep 05, 2004 12:38 am
Vinyl Flooring 3 740 Tue Apr 27, 2004 7:29 am
removal of permanent sharpie marker from vinyl floor 2 740 Tue Sep 14, 2004 12:19 am
Help remove ball point ink stain from my daughter vinyl doll 3 1360 Mon Apr 04, 2005 2:33 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
