DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Leaking centre spout
This topic originated from the How to page called Replacing O-rings and Gland packing
Click here to return to the page called Replacing O-rings and Gland packing.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Jagman
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 21, 2006 6:49 pm    Post Subject:
Reply with quote Thanks
The base of the centre spout on a Ideal Standard basin mixer tap is leaking and I need to replace the O-ring. How do I remove the centre spout as there is no screw holding it? I have tried moving it sideways but it doesn't appear to want to move.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
loafer
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 22, 2006 9:24 pm    Post Subject:
at the base of the spout where it joins the tap body there is a threaded nut which compresses the oring enough to seal it but aloows the spout to swivel... if it is hex shaped use adjustable spanner to release by turning counter clockwise. If it is round. not hex shaped. wrap a load of electriceal tape around it first... youl'll need sum adjustable water pump pliers but be carefull that you dont rip through the tape and scratch allo the noice chromm offa ya spout. inspect the rubber and the nylon ring fer damage... replace as neccesary... (dont tell anyone .... but!!! if ya email the manufacturer... theyll prob send ya a new nylon and rubber ring fer freeeeeeee shhhhhhhhh!!!) assemble in the correct way... apply more tape to the base of the spout if needed and tighten... hey presto!! job should be a goodun... carefully remove lecky tape... stand back and think of the money uv saved...
btw ill buy the pliers offa ya wen uv finished... dropped a pair of rothenbergers down a cavity 2day and am seriously miffed!!!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Can\\\'t remove mixer Spout 3 2480 Sat Feb 04, 2006 3:54 pm
monobloc swivel spout leak 9 6940 Sun Feb 27, 2005 5:28 pm
Monobloc Mixer tap spout is stiff to swivel 2 1720 Sat Oct 14, 2006 1:48 pm
loose tap spout 4 1740 Wed Feb 15, 2006 9:23 am
Separate Taps and spout - help... 4 400 Mon Feb 04, 2008 7:45 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
