DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
RCD for Bathroom Lighting
This topic originated from the How to page called Miniature circuit breakers (MCBs)
Click here to return to the page called Miniature circuit breakers (MCBs).
  View previous topic :: View next topic
Author Message
stevesar
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 22, 2006 11:24 am    Post Subject:
Reply with quote Thanks
Dear DIYnot, I wish to install Zone 1 designed downlighters over bath and understand I need a 30ma RCD in the lighting circuit for proper protection.
The relevant lighting circuit goes back to 5amp MCB in a Wylex 804 Consumer Unit (BS5486 Pt13) about 20 years old.
Is it possible to replace the MCB with a dual function MCB/RCD that will just plug in or am I into more complicated territory? There is no general RCD on the CU. Many thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 22, 2006 12:15 pm    Post Subject:
Re: RCD for Bathroom Lighting
The information you have been given is incorrect. The light fitting, if metal, needs to be bonded to other metallic objects within your bathroom but it does not need to be feed via an RCD
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Wed Feb 22, 2006 1:58 pm    Post Subject:
The way I understand it, a light fitting in zone one has to be IPx4 rated, and if mains has to be protected by 30ma rcd obviously you don't need an RCD if its selv, when you think about it, its very strange that you don't need an rcd for an electric shower
The following quote lists what you can install in zone 1
NICEIC article on zones and bonding wrote:
The following fixed current-using equipment
provided it is suitable for the conditions of the zone:
• a water heater
• a shower pump
• other fixed current-using equipment which can
reasonably be located only in zone 1, providing
the supply circuit is protected by a residual
current device having a rated residual operating
current, IΔn, not exceeding 30 mA in accordance
with Regulation or Regulation Group 412-06.
• SELV current-using equipment.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Feb 22, 2006 3:23 pm    Post Subject:
Have you not got the message that putting 230v lights in zone 1 is such a bad idea that it would be less trouble not to?
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 22, 2006 3:35 pm    Post Subject:
Back to top
 Alert Moderators
stevesar
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 10, 2006 10:22 am    Post Subject:
Zone 1 Lighting
Thanks to everyone for their advice. Sorry to take a while to reply but have heeded advice, and Zone 1 now has a very nice 12V light with transformer, everything else safely away in Zone 3, regards stevesar
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Bathroom Lighting 4 180 Sat Jul 25, 2009 12:46 pm
No earth in lighting circuit-question about bathroom lights. 3 640 Wed Aug 30, 2006 3:45 pm
Bathroom lighting circuit load 9 540 Tue Jun 15, 2004 9:30 am
Bathroom lighting -- additional switch and ceiling lamps 3 2320 Sat Dec 03, 2005 10:39 pm
Lighting in new bathroom 6 480 Thu Jan 06, 2005 12:03 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
