DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hot water coming from overflow pipe. Should I be worried?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
gotnomoney
from United Kingdom
PostPosted: Wed Feb 22, 2006 8:57 pm Reply with quote
Every so often (30 minutes or so), I get a loud rumbling in the loft, followed by a jet of hot water shooting out of an overflow pipe also located in the loft.
Looking in the loft, the rumbling is caused by boiling water going into the small tank, so much boiling water that it's the tank rocking around that's causing the noise.
After the water has gushed out, the ball valve drops and cold water fills the tank again. The water in this tank is very murky.
The hot water is also very very hot, despite having the thermostat on the boiler on it's lowest setting.
The boiler is an old Thorn M42/M44 floor standing thing.
When I bought the house 6 months ago the previous occupants informed me that the timer clock on the boiler had gone, so they fitted a plug in type one which has pins on to turn it off/on in 1/4 hour slots (it looks a bit like this one:
Anyway, the pump is also linked to this, so I can set the hot water/heating on and off with no problem.
Obviously I need to get a proper replacement for it - but the boiler looks so old, it may be better to replace it.
Also, the hot water tank in the airing cupboard looked very dodgy, with a big bit of solder on it which it was obviously covering up. I had this replaced with a new tank just after I moved in and long before teh gushing problem started - it's an indirect type if that's relevant.
The thermostat in the living room looks like it's seen better days and I'm not convinced it's working properly (if at all) as it doesn't seem to make any difference to the warmth in the house whatever setting I use.
The only real change I've done to the plumbing, as this was well before my current problem too, was to put a new bathroom suite in, only changing like for like - mixer shower head, two basin taps and a cold water pipe into the loo.
Other than the obvious "get someone in", is there anything I can do? Is it just a case of getting a new timer clock-thermostat unit and a new room thermostat or something more sinister?
If I've neglected to mention anything, let me know.
Thanks in advance.
Back to top
 Alert Moderators
gas chap
from United Kingdom
PostPosted: Wed Feb 22, 2006 9:09 pm Reply with quote
How hot are your rads?
Back to top
 Alert Moderators
gotnomoney
from United Kingdom
PostPosted: Wed Feb 22, 2006 9:24 pm Reply with quote
Very hot.
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 20 times
PostPosted: Wed Feb 22, 2006 9:27 pm Reply with quote
There's a serious problem with the boiler and you should stop using it until it's sorted! It sounds like a failed thermostat to me - not too expensive to replace.
Back to top
 Alert Moderators
gas chap
from United Kingdom
PostPosted: Wed Feb 22, 2006 9:29 pm Reply with quote
I concur
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Wed Feb 22, 2006 10:42 pm Reply with quote
This sounds more like a circulation blockage than a boiler fault. Are you able to identify the relative positions of the following:
cold feed pipe
vent pipe
circulating pump
When I say "relative positions", I'm referring to the fact that pump pumps in one direction, and am curious to know whether cold feed and vent are connected before or after the pump, and which comes first.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worried - Boiler acting strange....advice please!? 11 860 Sun Mar 16, 2008 3:28 pm
Big joist notch - worried 16 1000 Fri Dec 12, 2008 2:54 pm
HELP! Low pressure in my combi. Very worried!!! 10 860 Tue Jan 05, 2010 11:37 pm
Worried about weeping 6 620 Tue May 01, 2007 10:17 pm
Smell from boiler - should I be worried? 9 1160 Wed Feb 28, 2007 4:50 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
