DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
bath earthing help
This topic originated from the How to page called Installing a bath
Click here to return to the page called Installing a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
mrjc
from Thailand
Thanked: 0 times
PostPosted: Thu Feb 23, 2006 12:46 am    Post Subject:
bath earthing help
Reply with quote Thanks
i've got a metal bath and i'm going to use an electric shower to provide the hot water (this is in Thailand, so there's no other system of hot water in the house). The bath will be mortared, but what should i do about earthing the bath? The pipes used here are plastic, so I can't earth the bath to the pipes. The electricity supply is a two wire system, live and neutral. The shower gets an earth from the masonary wall it's attached to. Would earthing the bath to the wall be sufficient?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Thu Feb 23, 2006 7:24 am    Post Subject:
icon_eek.gif Do you mean bedded in mortar? I doubt if UK standards are applicable or appropriate to Thailand, so it's hard for us to comment.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
JPC
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 23, 2006 8:37 am    Post Subject:
i wouls suggest a wire from the bath to an earth rod that u will need to hammer in to the ground
like this one http://www.tlc-direct.co.uk/Products/TLER.html
nb ....dont hammer it thru the gas mains, electrics, foul waste, water mains, telephone wire or unexploded mines
__________________
Jamie
Back to top
 Alert Moderators
mrjc
from Thailand
Thanked: 0 times
PostPosted: Thu Feb 23, 2006 9:08 am    Post Subject:
sounds like a good option. there's a metal bracket on either side of the tub. would you bolt on the wire to one of these brackets or mig weld it onto the underside of the bath?
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 1 time
PostPosted: Thu Feb 23, 2006 6:32 pm    Post Subject:
the principle of earthing things in a bathroom is called supplementary equi-potential bonding.
The idea is simply that if everything is electrically linked then should one metal part become live, then all the metal parts in the room will be at the same potential.
Hence a person will not recieve the bad shock that would result if they were to touch two metal parts at different electrical potentials simulateously.
Back to top
 Alert Moderators
lcgs
from United Kingdom
Thanked: 33 times
PostPosted: Thu Feb 23, 2006 8:39 pm    Post Subject:
Dont forget if your bathroom has a radiator that should be earthed as well.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu Feb 23, 2006 8:45 pm    Post Subject:
Don't weld anything onto your bath or the enamel will fall off! If it has brackets already fitted, use them with stainless steel nuts and bolts. If it is cast iron it will be very difficult to drill it without cracking.
If you earth the water pipes going up to the taps as well that should be pretty comprehensive. You can usually use the same length of copper earth wire to go round multiple clamps.
Of course this assumes that you have connected the CPC of all the circuits in the bathroom (light, heaters, maybe immersion and shaver socket) into the same earthing set, and that there is an equivalent of a UK MET near the meter where the incoming suppliers earth is bonded to incoming services. If your country has a different approach you need to know how it works there, and why.
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Thu Feb 23, 2006 9:03 pm    Post Subject:
__________________
Let's face FAQs.
Back to top
 Alert Moderators
lcgs
from United Kingdom
Thanked: 33 times
PostPosted: Thu Feb 23, 2006 9:15 pm    Post Subject:
chris as you say, never assume: just because its nice doesn't mean they dont have heating.
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Thu Feb 23, 2006 10:03 pm    Post Subject:
Heating in Thailand! It's nearly on the equator! Even in the mountains in the far north of the country daytime temperatures rarely fall below 30C and nighttime temperatures rarely fall below 15C. I'm not making assumptions - it's just bleeding obvious.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu Feb 23, 2006 10:09 pm    Post Subject:
Better earth the air con ducts, then.
Back to top
 Alert Moderators
mrjc
from Thailand
Thanked: 0 times
PostPosted: Fri Feb 24, 2006 1:51 am    Post Subject:
thanks for all the tips guys.
the bath was mortared to the floor yesterday and i'll use a copper pipe in the ground connected to the exsisting brackets with bolts. The shower will also be earthed through the wall and it has it's own circuit breaker, so I think i'll be safe.
By the way, it does get cold here during the winter (Nov to Jan), especially in the evenings (if you come from England you'll think it's warm, but after living here five years you really feel the drop in temp.), but hardly anyone has heating in their home.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fitting a bathroom sink & Earthing a metal bath 7 720 Mon Sep 01, 2003 1:48 pm
Earthing A Bath 5 680 Fri Mar 09, 2007 9:41 am
earthing bath taps 16 740 Thu Jan 31, 2008 1:25 pm
Earthing a section of plastic pipe... 3 1100 Sat Jul 26, 2003 5:39 pm
Plumbing Earthing 2 640 Thu Jan 25, 2007 11:01 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
