all other radiators are fine except one on the bottom floor. it is getting hot at top and not at the bottom. have taken it off and flushed it, any other ideas / tips from someone more knowledgeable
thanks for that, before i rush out and buy a new one, not sure if its corroded cause i just turned all the other rads off and the defunkt one got really hot all over.....???
Try balancing the system, ie turning the lockshield valves down on all the other rads off and then opening them up half a turn and open the lockshield on this one up full. It may have been a slight blockage which you have now shifted by forcing all the flow through the one radiator.
I should have asked you first if you'd looked at other topics on this subject. OOPS!
It sounds like your system is not balanced - the purpose of balancing is to make sure that all radiators get equally hot.
You'll find this easy to do. Generally, if no adjustment was made, the radiators nearer the boiler would get the lion's share of the heat, so it's a matter of opening the radiator valves on the furthest ones and partially closing the valves on the nearest ones.
You can achieve the result using the rad valves that turn by hand, although the correct way is to remove the lockshield valve cover and adjust that one while the valve at the other end is fully open.
This is the principle - if you need more details then please search the forum for "radiator balancing" and come back here if you can't find what you need.
