DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
ceramic wall tile problem
This topic originated from the How to page called Tiling a wall
Click here to return to the page called Tiling a wall.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
bbp
from United States of America
Thanked: 0 times
PostPosted: Sat Feb 25, 2006 4:56 pm    Post Subject:
Reply with quote Thanks
How do I tile around wall plugs and an aluminum fan cover with ceramic tile?
THANK YOU for all the info!
BBP
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Nestor_Kelebay
from Canada
Thanked: 0 times
PostPosted: Sat Feb 25, 2006 5:25 pm    Post Subject:
Since you're located in the US, I'm confident I know what your electrical outlets are like since they're the same as those here in Canada.
In my view, it would be best to shut off power to the duplex receptacle and remove it, or at least shut the power off and pull the receptacle out of the box enough so that you can then re-install the receptacle so that it fits OVER the tiling. You will need to notch the tiles to accomodate the screw that holds the receptacle to the box.
Ditto for the fan cover. I'd take it off, tile up to the fan housing, and then re-install the fan grille over the tiling. (Alternatively, in both cases, consider if it's feasible to end the tiling before either the receptacle or the fan locations.
In the case of the receptacle, the screws that come with the receptacle should be long enough. In the case of the fan cover you might have to use a different type of fastener to secure it in place.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Removal of ceramic wall tile adhesive 2 1960 Sat Nov 27, 2004 9:37 am
how to cut hole's in the centre of a ceramic tile ? 2 760 Wed Jan 24, 2007 3:27 pm
Applying paint to a ceramic tile floor 19 1640 Mon Sep 26, 2005 6:44 pm
Ceramic tile sizes 2 2020 Sat Jan 06, 2007 7:13 pm
Ceramic Tile question. 2 1240 Mon Dec 15, 2003 2:09 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
