DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Help on Heating
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Russell Mark
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 26, 2006 4:33 pm    Post Subject:
Help on Heating
Reply with quote Thanks
Hope you can help me.
I have a gravity fed central heating system which I have drained to permanantly remove a radiator and pipework to it. I have capped the pipes and re-filled the system but now have no hot water or heating.
I have bled the system through all remaining radiators but I am only getting hot pipes to the pump and mid position actuator. The hot water cylinder is cold.
Can you suggest what may be the problem.
The boiler is working but the pump feels very hot and is making an intermittent groaning sound.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sun Feb 26, 2006 4:54 pm    Post Subject:
There are many possibilities.
For example, you might have a blockage in the cold feed from the F&E cistern. Check that the water level in the F&E goes down when you drain the system. If not, then search for "cold feed blockage" and you'll start to feel like you're a member of a large club!
You might have an air lock - go looking for all bleeding points on top of the boiler and on the primary circuit near the cylinder. Also, make sure that you vent all rads without the circulating pump running.
Back to top
 Alert Moderators
Russell Mark
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 26, 2006 5:01 pm    Post Subject:
Help on Central Heating
Thank you for your reply.
It was an airlock...I managed to clear it by bleeding all points and switching the pump to full.
Regards
Russell.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sun Feb 26, 2006 5:09 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Oil Central Heating Pressure 6 140 Thu May 29, 2008 11:34 am
Old HW and Heating System 3 120 Tue May 27, 2008 5:14 pm
supreme heating circuit board needed 4 440 Thu May 29, 2008 5:03 pm
Upgrading Heating - using second-hand? 2 180 Fri May 30, 2008 9:53 am
Halstead Best 50 Heating problem 7 300 Sat May 31, 2008 7:53 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
