keirik
Joined: 01 Mar 2006 Posts: 1 Location: London, United Kingdom Thanked: 0 times
Posted: Wed Mar 01, 2006 1:18 pm Post Subject: replacing radiator |
I want to replace a radiator with a towel radiator, but the valves currently exisitng come into the radiator from the side, whereas the towel radiator is designed for the entry from below, what sort of angled solution can I use? I cant move the pipes due to the flooring. I have looked on the web but can't find any appropriate L shaped connectors.
thanks |
Nige F
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
Posted: Wed Mar 01, 2006 2:41 pm Post Subject: |
I guess the T/R is narrower than the rad?.......use 2 new straight valves on the T/R and use chromed pipe and compression fittings to connect from old pipes to new valves.got to drain down tho`  Better ideas may be posted....keep watching and good luck. |
JPC
Joined: 10 Aug 2004 Posts: 1409 Location: Leicester, United Kingdom Thanked: 0 times
Posted: Wed Mar 01, 2006 3:20 pm Post Subject: |
not sure if i have undertood you properly....cant you just use angled rad valves with the heads (as it were) inwards, under the rad ? __________________ Jamie |
