DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
How do I remove a Danfoss Radiator Valve?
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
shirlmidd
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 03, 2006 5:27 pm    Post Subject:
Reply with quote Thanks
Can someone please tell me how to do this! The pin in the valve has stuck which means we have one cold radiator. The rad had been bled of air so we know that the problem is with the TRV. I am having difficulty removing the valve cover on the left side of the radiator to gain access to the pin for cleaning & greasing. The small black locking pin has been removed from the valve by the way! Thanks from a persistent lady DIYer. icon_sad.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Fri Mar 03, 2006 8:55 pm    Post Subject:
You have to twist the innermost black, knurled section in the opposite direction to the main body of the head - difficult to explain in words, but imagine you're wringing the neck of a chicken - this will release the clamping bits inside the black section.
When you've finally managed that, read the bit on sticking TRVs in the FAQ topic, otherwise you'll do the wrong thing with the pin which you think is stuck (it probably isn't!).
__________________
Let's face FAQs.
Back to top
The following user says thank you to chrishutt for this useful post:
Ferrar1 (13 Sep)
 Alert Moderators
ollski
from United Kingdom
Thanked: 10 times
PostPosted: Fri Mar 03, 2006 9:23 pm    Post Subject:
They have a little locking tab in the black ring aswell, you need to lever this out unless it has already been broken off....most have.
__________________
no to pointless signatures
Back to top
 Alert Moderators
superspudm
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 18, 2008 1:56 pm    Post Subject:
hey, i've got the problem as well but i haven't managed to remove any of it yet, does anyone know how to remove the cover?
alex
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Danfoss radiator thermostat - how do I remove it? 3 1060 Sat Nov 24, 2007 12:17 pm
Unable to remove shower diverter valve. 3 540 Wed Jul 06, 2005 3:53 pm
How to Remove Mid Position Valve head 3 240 Tue Sep 23, 2008 8:09 pm
HOW TO REMOVE A PUMA DIVERTER VALVE ?? 4 440 Tue Dec 06, 2005 8:58 pm
Remove a leaking radiator 7 420 Sat Feb 25, 2006 6:30 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
