Kilowatts Hour to Amps???
4 Mar 2006
Hampshire
"At the consumer unit, the cooker will require its own fuse way. A 30amp fuseway can support an appliance of up to 7.2kw providing that the control unit does not also have a socket outlet."
This appears to be our case, in which we aim to install an electric cooker in a circuit with a 30A MCB/fuse. Now, the irritating thing is, few online retailers will specify the overall power consumption of the appliances, while others will show the energy consumption in KW/h.
Say, what's the required fuse for a cooker with an energy consuption of 0.79, or 1.19 KW/h? Any handy formulas?
Thanks.
KWH doesn't tell you how much power an appliance takes at one time if I had a 7kw shower, and I used it for an hour, it would have used 7kwh hours (7 units), if I had a 1kw hair dryier and left it one for 7 hours, it too would have consumed 7kw, but they are totally different sized loads
The point I'm making is that kwh has time factored into it, and its used for telling how much you have used to take money off you, it means nothing in terms of designing circuits
kwh = kw * time (in hours)
I will ignore the fact that you got confused over kW and kWh
Power (watts ) = volts X amps
amps = Power / volts
Assuming UK supply is 230 volts
0.79 kW or 790 Watts / 230 volts = 3.44 amps
Thank you for both replies above.
I would like to mention it is not my confusion and am aware of the above.
That is the way catalogues (such as Argos) will give any indication of power consuptions and, correct me if I'm wrong, 3.44 amps sounds way below what a 4 hob ceramic cooker, oven and grill would take. Doesn't it?
Trying to find a suitable electric cooker online is proving quite a frustrating experience, given that hardly anyone will quote such an essential specification as this. We have a 30A fused circuit and aim to buy a cooker within that spec.
Or, you have sites like John Lewis saying things like "Power rating: 45 amps". Amps is not a power unit!!!! The only mention (for the same appliance!) in the manufactorers site is "30A fuse required" which sounds plain and dumb enough, but as the same legend repeats for all cookers (including the high consumption ceramic double ovens) I got to wonder. I have enquired about this and I look forward to a satisfactory reply.
Thanks again.
Thanks.
Your figures not mine :confused: :confused: :confused:
Having a quick gander at one of the Argos cookers I see a .79kWh specification. But it's for the oven, not the hob.
For example http://www.argos.co.uk/static/Produ...5948.Cookers>C$cip=35953.Electric+cookers.htm (Zanussi ZCE7551 Stainless Steel Electric Cooker) says top oven is .79kWh and bottom is .98kWh, but it doesn't say anything about the hob rating. Ovens can be run off 13A plugs so the two ovens will take about 7.7A if on together. That is if Argos are trying to say kW and not kWh.
Thats the energy efficiency rating figure - the amount it uses each hour. Not the rating of the actual elements! I have concluded this is a bad idea as it may lead DIYers to start putting these cookers on 13A plug tops, uner the impression the whole thing will only ever consume <1kw (them not knowing any typical figures for cookers etc) :confused:
just read up on energy efficiency ratings
they are quoted in kWh :eek: :eek: :eek:
imagine an oven rate at 5 kW
It will take 5000 watts / 230 volts = 21.74 amps
if you assume the heater cycles on for one minute reaches temperature then swiches off for four minutes then in one hour it will consume
(12 minutes / 60 minutes) x 5 kW or 1kWh
I can see the confusion now :eek: :eek: :eek:
