DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Decorating
This topic originated from the How to page called Preparing Walls and Ceilings
Click here to return to the page called Preparing Walls and Ceilings.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
Kavie
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 04, 2006 7:28 pm    Post Subject:
Decorating
Reply with quote Thanks
Can someone please tell me an easy quick way to paint over walls previously coated with gloss paint?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Sat Mar 04, 2006 11:13 pm    Post Subject:
Give the walls a wash down with wet and dry paper to key it. Then give it a couple of coats of the chosen emulsion. It might even take 3 coats depending on the starting and finishing colour. As always, don't take my word for it - wait for the approval of a "time served" tosher before proceeding. icon_wink.gif
__________________
If I'm curt with you it's because time is a factor. The Wolf.
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 0 times
PostPosted: Sat Mar 04, 2006 11:15 pm    Post Subject:
1. Paint over the walls with a sticky primer like Zinsser's Bullseye 123 emulsion primer, and allow to dry. Zinsser's boasts that their primer will stick to hard-to-stick-to surfaces such as glazed ceramic wall tile, high gloss polyurethane floor finish, galvanized metal, etc.
http://www.zinsser.com/product_detail.asp?ProductID=11
Here's a UK site that sells the stuff:
http://www.decoratingdirect.co.uk/techdata/z/ZINBE/
2. Paint over the dry Zinsser's Bullseye 123 with your top coat paint.
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Sat Mar 04, 2006 11:29 pm    Post Subject:
I'm sure that'd work Nestor, but I'd use that as a last resort if the keying didn't work. That's expensive stuff you know.
__________________
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 3 times
PostPosted: Sun Mar 05, 2006 11:43 pm    Post Subject:
Using wet and dry to form a key is probably the best form of preperation for paint..however
Is a hell of a task over a big area, a couple of square metres may take me an hour (especially if im being paid by the day!!)..a whole room could be a very long job..not to forget the fact that each sheet is about a quid..
Id rub the walls down using 100 grade aluminuim oxide paper (thats 'alooominham' to you nestor) and then coat em with either acrylic primer undercoat..or dulux super grip primer (thinned by about 20%) ..Zinseer, as Gcol says is expensive stuff over here...about 14 quid a quart...
Or..you could always use an oil based undercoat..thinned by about 20%...allow to cure thoroughly for a couple or three days...then emulsion it..out will stick fine...but the only problem is painting oil based paint over a large area isnt to clever fume wise
__________________
How much!
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Mon Mar 06, 2006 9:22 am    Post Subject:
Zampa me owd china, you need to move your arm a bit faster and not be so particular. Only joking. Surely you only need to just lightly break the surface sheen though? I'd probably just run round the room with the random orbital sander, dust off and then wallop some paint on.
__________________
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 3 times
PostPosted: Mon Mar 06, 2006 6:52 pm    Post Subject:
Quote:
and then wallop icon_mad.gif some paint on.
tutututututututut...apply...the word is apply...
Your dead right though..you do only have to break the surface..etch it..but its a tough call doing a whole room like it..and quicker to paint...although you should still ket it up a bit
...one word of advice...
Dont dip the sander in a bucket of water if your going to use it with wet and dry.. icon_eek.gif .Zuuuzzzzzzzzzzzz <----(poor attempt at an electric shock sound)
__________________
How much!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
kitchen decorating 3 380 Sun Sep 30, 2007 4:34 pm
painting and decorating 9 700 Mon Nov 26, 2007 5:50 pm
ceiling decorating 2 360 Fri Feb 01, 2008 3:29 pm
decorating behind radiators 7 460 Sat Feb 02, 2008 10:55 am
decorating and painting 3 340 Thu Sep 27, 2007 8:20 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
