dishwasher never finishes - sticks on 1 minute
6 Mar 2006
Kent
My Bosch logixx - sgs66a02 washes perfectly, but never finishes the cycle. It gets down to 1 min remaining and then humms forever until I turn it off by resetting. It then seems to drain but the dishes are never dry. Help?
I have the same problem, has anyone located a site that lists test codes so that we can fault find ourselves. Maybe this site should list them,?
it will remain this way for a while until it only displays 2h. there is likely a failing circuit pad on the control board. Call and complain to Bosch at their 800 number. If it is still under warranty, then if you complain enough, they will cover the cost of the repairman and the board. Otherwise they will offer a discount on the control board. of course, it will be backstocked due to it being a common problem.
