""mm central Heating pipework run.
17 May 2005
Fife
Hi Everyone.
Well I decided to save a grand and re run my central heating pipe work.
I am using 22mm supply and return and 15mm to radiators.
I want to run a loop system.
Is there any advantage of running the 22mm pipe work in a continuous run ie from left to right (IE U shaped.) Or just using a T piece from where the pipe comes down from the boiler and going left and right.( this is easier for me).
Hope this is as clear as my radiator water, but thats another thread.!!!!
There's no need for a continous loop of 22mm - in fact you will get a partial short circuit. You run the 22mm to main areas and then go local in 15mm for the radiators. A 15mm flow will support 3-4 radiators. The same for the return.
The single pipe system (what you call loop) is no longer used in domestic.
Hi
So it would be ok to branch off from the down pipe and run a single lenth in each direction ( house is split into two sections under the floor) , T ing off 15mm to each radiator.
IE one single length of 25 mm will feed 4 radiator whereas the other length will feed 3 radiators.
flow out of boiler to one side of radiators, return to other side of radiatos. radiators make the loop .
