DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
stop cock not stopping
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
bigpete
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 09, 2006 9:42 pm    Post Subject:
Reply with quote Thanks
when I turn off the interior stop cock the hot water taps dont run any water when open. However, all cold water taps run as normal with no visible change in pressure......help, my old bathroom is out and I need to run a new cold & hot water pipe b4 i can put the new 1 in......the wife is goin nutz!!! ohyeah, the outside stop appears to have been tarmacced over by NTL! Is there a way of replacing the inside stop while the feed is still live (or would that just flood the kitchen and make the wife kneecap me?!!)? icon_cry.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
wouldbplummer
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 09, 2006 9:50 pm    Post Subject:
are you sure you have that the right way round if youve turned stop tap off you will have no water out of cold taps but you will have hot but only untill you run all your water out of tank then this will stop to.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Thu Mar 09, 2006 9:53 pm    Post Subject:
you will just flood the kitchen, highly unadvisable to do it live
get on to your water company and get them out to find the external stop cock they should be willing
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 1 time
PostPosted: Thu Mar 09, 2006 10:07 pm    Post Subject:
There must be another stop cock inside - follow the pipes. The one you are turning off is probably a secondary stop cock just for part of the system.
Back to top
 Alert Moderators
bigpete
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 09, 2006 10:19 pm    Post Subject:
it is definatley the only stop tap, it is about 6 inch above where the pipe comes in to the house thru the floor.
my mum used to have this house about 15 years ago and she has told me that it is the right one. Is it possible that the interiors have corroded? the hot water starts running as soon as i open it again!
what are these fraazing kits that I have heard about and where can I get one from (reasonably priced) and do they work and how do I find out what size diamater fitting do I need an and and and my flamin ed urts!
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 1 time
PostPosted: Fri Mar 10, 2006 1:10 pm    Post Subject:
If your stop cock is turning the hot off, where is the cold coming from ?
Unless you have a cold tank - this may explain the cold in the bathroom.
But the kitchen tap must be on the mains - so where is that connected to ?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
leak stopping compound 2 260 Sat Sep 01, 2007 3:22 pm
Myson Valaire boiler keeps stopping and starting 3 760 Sat Feb 10, 2007 1:33 pm
Pump Stopping and starting when boiler re-fires 2 360 Sat Sep 29, 2007 3:39 pm
Solution for stopping the noise of a tank filling 10 480 Sat Oct 27, 2007 10:05 pm
Stopping radiator water supply? HELP! 10 320 Sun Dec 16, 2007 10:50 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
