DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
washing machine drain options
This topic originated from the How to page called Installing a washing machine
Click here to return to the page called Installing a washing machine.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
trazarra
from United States of America
Thanked: 0 times
PostPosted: Sat Mar 11, 2006 5:44 pm    Post Subject:
Reply with quote Thanks
my washer currently drains into a sink that drains into a drywell.....the drywell seems to be failing & i believe i reached a tree root when trying to snake it.....can i connect to my city pipe somehow?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
trazarra
Thanked: 0 times
PostPosted: Sat Mar 11, 2006 7:53 pm    Post Subject:
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 0 times
PostPosted: Sat Mar 11, 2006 8:16 pm    Post Subject:
Sure. Do you have a floor drain nearby, and if so, does it drain into your city sewer system?
Back to top
 Alert Moderators
trazarra
Thanked: 0 times
PostPosted: Sun Mar 12, 2006 12:10 am    Post Subject:
washer drain
no drain in the floor but my city pipe is nearby.....can i tap into it?
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 0 times
PostPosted: Sun Mar 12, 2006 3:46 am    Post Subject:
I don't see a problem draining into your home's drainage piping, since that's how it's normally done.
You need to ensure that the elevation of the end of the drain hose is at least at or slightly above the level of the top of the machine. Otherwise, water will drain out of the machine during the agitate cycle, and it shouldn't. The drain hose should keep the water in the machine until it's pumped out during the spin cycle.
Maybe just check with your local plumbing inspector about draining into the nearby drain pipe just to make sure, tho. I don't see any problem doing that.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
DVD Wide screen - options ? 16 780 Mon May 09, 2005 11:16 am
Humax Freeview PVR-8000t lost menu options 5 280 Wed Jun 18, 2008 8:39 pm
washing machine drain sewer smell 5 14460 Sat Mar 06, 2004 4:00 pm
BOSCH WFL 2260 washing machine won't wash, will drain 2 340 Sun Sep 07, 2008 7:31 pm
Partially blocked drain from washing machine 2 860 Sat Sep 29, 2007 7:49 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
