DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Wiring mirror demister in bathroom
Author Message
Jackuzi
from United Kingdom
PostPosted: Sun Mar 12, 2006 10:04 am Reply with quote
Hi all,
I am refitting my bathroom from scratch and will be putting a 1m square mirror on the wall over the bath central to a tiled wall. This will be attached to 6mm WBP using mirror adhesive then onto the wall. I have seen these self-adhesive demisting pads and want to fit one to enable shaving whilst showering in that area.
Onto the question - having removed an electric shower from that wall I have the wiring that went to it. Can I use this wiring to run the demister? I also want to connect the extractor fan to this circuit as well so they run at the same time. I will probably install another demister to the mirror (1.5m x 1.5m approx) on the wall over the basin/wc worktop. I could then use the isolating pull switch (previously isolated the shower) to switch all of this on and off.
I am thinking the wiring is obviously overkill to run all this and will need to change the size (Amp) of the plug in trip fuse at the consumer unit?
Have I got this in my head okay or am I going about this the wrong way?
Thanks,
Glen
Back to top
 Alert Moderators
baldelectrician
from United Kingdom
Thanked: 6 times
PostPosted: Sun Mar 12, 2006 10:36 am Reply with quote
possible
a couple of things
1. part P
2. Bonding requirements- see for reference
Back to top
 Alert Moderators
Jackuzi
from United Kingdom
PostPosted: Sun Mar 12, 2006 11:18 am Reply with quote
So basically I have two choices - get an electrician to do it or get it inspected by local authority?
Back to top
 Alert Moderators
slippyr4
from United Kingdom
Thanked: 5 times
PostPosted: Sun Mar 12, 2006 11:37 am Reply with quote
Yep. You get to thank Uncle John Prescott for that.
Back to top
 Alert Moderators
baldelectrician
from United Kingdom
Thanked: 6 times
PostPosted: Sun Mar 12, 2006 11:40 am Reply with quote
the two choices you have are either to do it right (to BS7671 and to Building Regs) or not.
To do it right you have 2 options- DIY to BS7671 and local council inspection or use a registered contractor.
It's your money and your choice.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Demister pad connection on illuminated bathroom mirror 9 140 Fri Mar 14, 2014 3:21 pm
Mirror Demister Pad - Orientation 9 140 Sat Mar 23, 2013 7:54 pm
wiring heated/backlit mirror in bathroom 10 2020 Mon Oct 20, 2008 1:08 pm
Advice req. on routing bathroom mirror heater wiring. 2 580 Sun Aug 03, 2008 9:27 am
Bathroom mirror wiring 8 160 Mon Sep 01, 2014 9:35 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
