brown water coming from hot water taps
13 Mar 2006
Wiltshire
Help! brown water coming from hot water taps after draining system and replacing two leaking radiators and installing trv's :rolleyes:
I suspect your system is primatic and a air pocket dispersed whilst draining. In a day or two it should settle down and stop.
Need more info on your sytem to confirm though.
what imformation would you need? i can tell you that the system has 2 tanks in loft with hot water cylinder in airing cupboard with pump and a diverter valve for hot water and heating? :LOL:
not really just put in some inhibitor,there was quite a big air lock that took a while to clear. ie bleeding radiators,pump
primatic :?: :?: :?: :?: :?: :?: :?:
methinks not
as i say to the dog
you are peeeeeeeing up the wrong lamp marra
u might have disturbed muck in ur cwsc. run a load of hot water off. go and have a look at the water colour in the cold water storage cistern in the loft (the large one)
if after all this its still brown come back to us...
methinks not
as i say to the dog
:oops: as ever kev is here to put us mere mortals right
all hail king kev
