steve2301
Joined: 15 Mar 2006 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Wed Mar 15, 2006 10:32 am Post Subject: flickering halgens |
I have recently had some low voltage holgens fitted to my living room. I have a circuit of 8 35W dichronic halogens each with their own 20-60VA electronic transformer. I have connected a 400W dimmer switch and the lights flicker intermittantly on start up? It seems to go away after a while but overnight the problem re-occurred. Is the problem in the dimmer switch, i.e is there a max number of lights i can run on the switch. I\\\'m reluctant to go back to standard switch, i want the opportunity to dim the white light? The room is boarded up now, dont want to have to re-wire etc. Any help would be most appreciated. |
lewislee
Joined: 17 Mar 2006 Posts: 46 Location: Kent, United Kingdom Thanked: 0 times
Posted: Fri Mar 17, 2006 2:44 pm Post Subject: |
check your transformers some are not suitable for dimming! in my experience jcl are a good make to get and work every time without problems |
