I have a Potterton Flamingo 40 boiler downstairs, a hot water storage tank upstairs and two open tanks in loft.
Hot water works fine but CH does not work at all. Boiler fires up for CH but cuts out after a couple of minutes.
Checked tanks in loft and they're ok (2/3 full)
Thermostat (only one in house, on wall of living room) is set high enough and I think it's working as I roll dial up and down past room temperature I hear it 'click'
Thought problem might be pump as I heard intermittent whirring. Replaced with like for like (Myson CP53). seemed to work at first but after an hour same problem returned. Follwed manufacturers' advice on turning it manually but same problem on restart. Pump now runs but rhythm still isn't constant. ie seems to speed up then slow down. also a water 'rushing' noise every minute or so. Problem same on all speed settings, sometimes accompanied by occasional whistling noise.
All rads have water (bled them all).
Boiler sometimes fires up when adjustment to it's dial (1-4)made but same problem returns.
Could problem be sludge in system?
If so, what should I do to solve it?
I have a SUNVIC controller if that's relevant.
Any advice would be greatly appreciated.
Thanks,
Graham
Thanks,
Graham
