DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Calculate heat output of existing radiators
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
theGman
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 17, 2006 8:18 pm    Post Subject:
Reply with quote Thanks
Hi, i'm looking to change the radiators in my house and would like to know if there is anyway to calculate the heat output of the existing radiators. The house has quite large rooms and the radiators seem to be very small, therefore the rooms always feel cold unless the heating is on for extended periods.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Fri Mar 17, 2006 8:23 pm    Post Subject:
Get hold of any radiator catalogue (e.g. via web sites) and find rads of similar size and configuration to your own. The outputs given will be much the same. If you have single or double panels without fins you may not find modern equivalents, but if you reduce output of finned panels by 30% you will have an approximation.
A better approach is to compare the temp. achieved by existing rad to desired temp. in relation to external temp. E.g. outside temp 1C, desired room temp. 21C, actual room temp. 16C, need to increase rad output by 33%. But check also that rads are getting up to temp. - if boiler flow is on max (82C) and return is 70C then average rad temp. should be 76C.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
theGman
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 17, 2006 8:28 pm    Post Subject:
Thanks for the fast reply I'm now off to measure all my radiators, why can't I have something else to do on a Friday night?
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Fri Mar 17, 2006 8:31 pm    Post Subject:
Note my later edit of previous post.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Mar 17, 2006 8:50 pm    Post Subject:
My unscientific method, with rooms that didn't seem adequately heated, was to replace all the singles with double finned of the same length as I decorated the rooms. You have to put TRVs on of course otherwise you might get overheated, and you can fit new lockshields and drainoffs while you're at it. It's much easier to decorate and paint with the rads off anyway. Spare rooms are turned right down.
I suppose if you had an undersized boiler it wouldn't be the right solution, but I had my cavities filled since the house was built, so it's now plenty big enough.
Back to top
 Alert Moderators
theGman
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 17, 2006 9:18 pm    Post Subject:
An example of my room comparison to size of existing radiator is my 2nd bedroom which is 13' 4" x 9' 7" by @ 10' high and the radiator is only 700mm long. This bed room is always very hard to heat up, it has 2 external walls, another room is 14' 6" x 12' 11" and the radiator is 900mm long. The boiler is a Vokera Excell 80SP, the problem is that it gives me 2 possible max outputs for 2 different inputs, so I don't know wether the boiler is struggling or if there is spare capacity to increase the size of the radiators.
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Fri Mar 17, 2006 9:29 pm    Post Subject:
That will deliver 24kW output (except when it's doing HW), so you'd need a hell of a lot of rads to overload it!
JohnD's point about oversizing and fitting TRVs is a good one. When you eventually get a condensing boiler oversizing will help it to run in condensing mode and maximum efficiency.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
theGman
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 17, 2006 9:34 pm    Post Subject:
I'm also using it for my hot water supply
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Fri Mar 17, 2006 9:39 pm    Post Subject:
Do you mean apart from it's Combi function? I'm assuming that it's a combi boiler and that when you're not actually running HW the full output is available to CH. In practice you can assume that most of the 24kW can be available for rads, although you''re unlikely to get near that unless it's a very big house.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
theGman
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 17, 2006 9:44 pm    Post Subject:
thanks for all the help now to buy new radiators.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
How do I calculate water volume in CH pipes 5 680 Thu Sep 30, 2004 9:48 am
How to calculate water flow in property? 8 280 Thu Aug 20, 2009 4:51 pm
how to calculate a pipe run length 4 140 Sun Sep 27, 2009 5:33 pm
How do I calculate the size of radiator I require 4 660 Wed Oct 11, 2006 3:02 pm
35 kW heat output HE boiler on 22 mm heating circuits? 28 1420 Mon Sep 08, 2008 9:10 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
