anglerls
Joined: 19 Mar 2006 Posts: 2 Location: Canada Thanked: 0 times
Posted: Sun Mar 19, 2006 7:10 pm Post Subject: Installing dimmer switch |
Greetings,
I want to install a sliding dimmer switch in my home on a two way circuit. My living room lights can be switched on at two places. In the living room is where I want to install the dimmer switch I have. It only has two black wires coming out the back of it. Can I proceed and how? |
sparkythespark
Joined: 16 Mar 2006 Posts: 14 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Sun Mar 19, 2006 9:00 pm Post Subject: TWO way or not two way that is the question. |
Sounds to me this is a one way switch. Is this a true two way or is it a PART TWO WAY. meaning has the a switch been added at a later date.
ie can it be turned on at one end and of at the other and again on back at the other end . Check this out get back to me. |
anglerls
Posted: Sun Mar 19, 2006 9:52 pm Post Subject: |
I had been using it(the dimmer switch) in a room that only had one light switch in it but I removed it and thought that I could install it in my living room. The living room has two switches operating the pot lights. One switch in living room and other in dining room.
I thought I recall when I bought the switch a few years ago it came with some sort of a jumper and I didn't need to use a 2 way switch on a 2 way circuit. Can you please elaborate? |
Steve
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Mon Mar 20, 2006 4:12 pm Post Subject: |
Canadian electrics are very much different to UK electrics, so i suggest you consider asking on a US forum, as things like dimmer switches will vary considerably across the pond. |
