DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
15mm pipes to bath!
This topic originated from the How to page called Installing a bath
Click here to return to the page called Installing a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Scousemooncat
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 20, 2006 10:41 am    Post Subject:
15mm pipes to bath!
Reply with quote Thanks
Hello All,
I am plumbing in a new bath to under an existing powershower...(its a Victorian Terrace that once had a bath but the previous owners took out the bath and put in a double shower cubicle..boooo)As the pipework stands at the moment it is 15mm pipe that runs to the powershower and I was hoping to t-piece off this pipe and connect to the bath - is there any detrimental effects of using 15mm to plumb in the supply to the taps? - the taps are quite small bore too....HELP?...to replace the 15mm piping entirely would need a huge undertaking of tearing up the tiled floor icon_confused.gif and re-laying 22mm pipes etc...any comments/help welcome!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Mar 20, 2006 10:57 am    Post Subject:
Is it a combi boiler? Is cold water off the mains, or from a tank?
Back to top
 Alert Moderators
Scousemooncat
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 20, 2006 11:28 am    Post Subject:
Central heating and hot water are separate - (heating is run off back boiler downstairs)...cold water is run off the tank in the loft, with the hot water boiler being supplied by a tank on top of the boiler in the bathroom...
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Mar 20, 2006 11:48 am    Post Subject:
Then you ought to have 22mm pipes, otherwise the bath will fill so slowly that it annoys the users every time. You might consider running them round the bottom of the wall with extended skirting to hide them, or just bite the bullet and redo the floor.
Back to top
 Alert Moderators
Scousemooncat
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 20, 2006 1:18 pm    Post Subject:
Thanks for the advice - I think the flooring route is the way to go!.... icon_biggrin.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
15mm bath pipes 3 160 Sun Mar 01, 2009 4:40 pm
No 15mm pipes in bathroom ?!! how to install bath ? HELP !! 11 920 Mon Nov 01, 2004 4:50 pm
8mm to 15mm pipes 5 280 Fri Mar 23, 2007 12:14 pm
15mm vs 20mm pipes 2 560 Tue Nov 30, 2004 2:13 pm
22mm pipes instead of 15mm? 6 640 Wed Feb 23, 2005 1:40 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
