replaced diaphragm, switches, and hot water sensor. Hot water kicks in when taps turned on, but bolier not return to Central heating or standby, but stays running constantly. Any ideas please please please
Did this happen before all these parts were changed?
Is the micro switch operating correctly, does the heating operate or does boiler overheat when water turned off? does this happen in water only setting???????
It gets a bit tedious Kev giving correct advice all the time. If you change all the bits ( like BG ) then eventually you will get it to work!
He has probably got a blocked capillary tube to the diaphragm unit or failed to clean and lubricate the actuator pin with silicone grease ( whats that? )
