DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Broken board beneath my roof
This topic originated from the How to page called Tiled Roof
Click here to return to the page called Tiled Roof.
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
  View previous topic :: View next topic
Author Message
erskine
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 22, 2006 9:01 am    Post Subject:
Reply with quote Thanks
I have recently noticed when in my loft that quite a number of the boards upon which the felt and then the tiles are placed are bulging away from the joists and some are cracked.
Should I be worried about this and what can I do about it? The board seems to be plywood.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
peca27
from United Kingdom
Thanked: 1 time
PostPosted: Thu Mar 23, 2006 3:27 pm    Post Subject:
yep i'd be worried
The construction of ur roof is tiles on battens on roof felt on plywood + then fixed onto the roof truss. If the plywood is bulging it's got water into it - sounds like u might be havin a leak in ur roof.
If it continues, + all the ply fails, u wud be lookin at lifting the whole roof + fixing new plywood + then relaying the roof.............not cheap
Get up there + fix the leaks sharpish
Back to top
 Alert Moderators
erskine
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 23, 2006 6:28 pm    Post Subject:
Thanks. I'll check the next time it rains. There doesn't appear any sign of dampness on the plywood but it may be that it has dried out.
Back to top
 Alert Moderators
splinter
from Antarctica
Thanked: 0 times
PostPosted: Thu Mar 23, 2006 7:43 pm    Post Subject:
That's why the ply( or in you're case closed boarding) has probaly bulged .because it keeps on getting wet and drying out
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
replacing broken roof tile 8 660 Sun Mar 16, 2008 3:28 pm
Easily broken tiles 2 580 Wed May 31, 2006 7:58 am
Broken drain gutter 5 520 Sun Oct 28, 2007 9:40 am
Tile under end ridge tile broken 4 440 Mon Aug 13, 2007 2:02 am
chip board under felt roof 7 1940 Sun Jan 13, 2008 10:24 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
