sheeraz1
Joined: 03 Aug 2005 Posts: 7 Location: London, United Kingdom Thanked: 0 times
Posted: Wed Mar 22, 2006 3:50 pm Post Subject: Cold Upstairs/Warm downstairs |
Hello guys
Trying to find some answers. I have a 2 up 2 down mid terrace house and find that upstairs is not as cosy as downstairs. theres a marked difference in temperature. All radiators seem to be fine and the rooms are not that big. I had a look in the loft and the insulation seems to be ok. Would it help to reinsulate the loft floor with foil backed sheets and vapour barriers? Will this help rising heat back into the house? Or is there somebody else that could be causing the cooler temp upstairs
thanks for any advice |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Wed Mar 22, 2006 3:55 pm Post Subject: |
It might be by design. Bedrooms are widely heated to a lower temperature than living rooms. You might find the rads are smaller, or you might find they're been balanced that way. I'm assuming it's not done by TRVs or you would have adjusted them; equally I'm assuming that the walls and windows are of the same construction or you'd have mentioned it..
What is the thickness of the loft insulation, and is it complete cover or does it have gaps or poor fitting against the roof timbers?
BTW do you habitually wander about your bedroom in a flimsy negligee, rather than the sturdy woollen suiting you wear downstairs? Maybe you just feel the cold more  |
Nige F
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
Posted: Sun Mar 26, 2006 3:22 pm Post Subject: |
Post in Plumbing  There are knowledgable guys from London on that forum
MOD 2
your wish sir is my command  |
