DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
additional radiator
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
donko
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 23, 2006 9:15 pm    Post Subject:
additional radiator
Reply with quote Thanks
i wish to add an extra radiator for my garage conversion.Is it possible to tee into an exhisting radiator in my hallway.The feed and return pipes are 10mm copper,the new radiator would be mounted on the rear wall of the hallway,new pipework would be about 2m in length.To tee back into the 22mm pipes would be a nightmare as laminate flooring is layed throughout the house. icon_rolleyes.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Expertboy
from United Kingdom
Thanked: 1 time
PostPosted: Thu Mar 23, 2006 9:18 pm    Post Subject:
__________________
i accept no responsibility for any of your mistakes whether you took my advice or not icon_smile.gif
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Thu Mar 23, 2006 9:25 pm    Post Subject:
Teeing into 10mm pipe could be a problem. It depends on the extent to which the 10mm is already fully loaded by the existing rad, how much extra load you're adding on and exactly where in it's overall length you're teeing in. You may find that the circulation to one or both the rads fed by the 10mm becomes sluggish and the rads don't really get hot enough.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
donko
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 23, 2006 9:56 pm    Post Subject:
What would you suggest, as the 22mm pipes are not accessible?
The new radiator will not be to big, and im keeping the pipework as short as possible. icon_rolleyes.gif [/quote]
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Adding an additional radiator to a combi CH loop 2 200 Sat Aug 22, 2009 2:57 pm
ADDITIONAL RADIATOR 5 560 Sun Jan 14, 2007 7:55 pm
fitting additional radiator (T or loop) 3 280 Mon Jul 07, 2008 6:57 pm
Can I have an additional radiator 14 840 Wed Oct 13, 2004 3:48 pm
Fitting additional radiator to sealed system 3 1360 Fri Oct 01, 2004 10:06 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
