DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Priming ply for tiles
This topic originated from the How to page called Tiling a wall
Click here to return to the page called Tiling a wall.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
Bjorn
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 24, 2006 1:05 pm    Post Subject:
Reply with quote Thanks
Can you please recomend a suitable sealer for exterior grade ply to use prior to wall tiling? Also, is there a minimum thickness ply to use when covering the wall (it had lots of holes)
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Moz
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 24, 2006 1:14 pm    Post Subject:
you can use a pva sealer but ,check that the adhesive product allows this
I would use 12mm on battens , you could also use aquapanel tile backer board instead of ply , !
Back to top
 Alert Moderators
arctic
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 24, 2006 4:01 pm    Post Subject:
I'd strongly advise against pva, I know loads of people use it and it works ok but if it gets wet you may have problems.
I'd use a specific tile primer howtex, bal e.t.c. all do one not very expensive and the right product for the job.
What are you sticking the ply to the wall with? The thickness of the ply is a bit dependant on what your doing with it, if its for boxing in and your using light tiles then 12 mm would probably be ok, but I like to use 18mm well fixed so there's less likelyhood of thermal flex (you'll get some but not too much...)
Make sure you use a good quality flexible adhesive as well (non slip would help too if its walls your tiling.)
Good luck with it.
Kev
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
wood knotting & priming 2 560 Mon Feb 18, 2008 4:20 pm
spot priming exterior windows 2 220 Wed May 13, 2009 7:47 pm
Patchy paint appearance when priming recently skimmed walls 12 4480 Sun Apr 16, 2006 2:26 pm
Priming & painting putty 4 2620 Tue Jan 23, 2007 12:45 pm
Priming Coving before painting. 7 2240 Sun Jan 29, 2006 9:36 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
