Agile said:
A more elegant solution is to disgard the on board clock and fit a programmable thermostat.
Hi Tony, thanks for taking the time to reply. I may pop the programmer off again to take a look, but I don't remember noticing anything that looked obviously like a battery when I fitted it.
Your final comment leads me onto another question that I wanted to ask though, if you don't mind
(Actually I have several, but I'll take it one at a time so as not to get on anyone's nerves!)
My boiler/central heating was fitted in October/November 2004. I'm very happy with the work in general, but when I discussed the system with my installer, he said that a room thermostat wasn't necessary, and that I'd be best with TRVs in each room, excluding the towel radiator ('because a central heating system needs one rad permanently open if all the others have TRVs').
My partner is soon to have her boiler replaced, and both the company reps we've spoken to so far have said that she *must* have a room thermostat, with TRVs in the other rooms (i.e. that it's a legal requirement). I've read around on the web and found info on legislation that was introduced in April 02 that seems to confirm what the reps have said.
Would you mind confirming for me what position I'm in? Should I be retrospectively installing a 'stat? If I didn't, would my flat be non-compliant with the requirements for the seller's pack coming in in 2007?
I also don't know if there's a bypass circuit fitted in the pipework he did, and although I have a receipt from him, I don't have any other certification - should I?
I should point out that I trust this guy, I'm just wondering whether there are a couple of things he's not quite got right!
Cheers, Luke
