Hey all,
Came home today and found a slight roof leak around my flue going through the ceiling (single storey had loads of rain today) It had dripped on to my boiler, it wasnt much a few paper towels worth, but the boiler has stopped responding to the room thermostat in the living room (run off batterys, connected by 2 wires into the boiler circuit board) I have changed the batterys in the room thermo, but the boiler does not respond to the "call of heat" from it, it has reverted back to a boilers default which is running off its own thermostat, ran off the temperature dial for the radiators, which is on the front of the boiler, this shouldnt happen as the bridging wire has been removed and replaced with an independant wires from the room thermo. I have checked connections they are fine, its been running fine from the room thermo for 18 months, so after seeing a slight dripping of water today from the roof (i will sort out when we have better weather, there is now a "drip tray" on top of the boiler!) I think that water has entered the circuit board and caused this problem (not so much a problem if thats the way it has to be) What Im wondering does anyone agree thats the cause and do you reckon it will resume its previous state when the circuit board is dry?
Cheers
Cheers
