Farl
Joined: 28 Mar 2006 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Tue Mar 28, 2006 5:02 pm Post Subject: Creaky floorboard / joist? |
I have a creaky floorboard which has been nailed and screwed down repeatedly but with no joy. The last builder said that he thought it was a problem with the joist, or could be because pipes run under the floorboards. Is there anything that can be done? |
splinter
Joined: 10 Apr 2004 Posts: 778 Location: Antarctica Thanked: 0 times
wedge69
Joined: 14 Jun 2005 Posts: 209 Location: Worcestershire, United Kingdom Thanked: 0 times
Posted: Wed Mar 29, 2006 9:13 am Post Subject: |
If there are hot water pipes underneath then the board could be expanding, so when you tread on it it rubs with the neighbouring boards causing the squeak.
Just take it up and shave a bit off the sides.
Apparently, putting talk in the gaps might help too. |
splinter
Posted: Wed Mar 29, 2006 9:31 am Post Subject: |
wedge69,
Try talc  |
Moz
Joined: 19 Jun 2005 Posts: 5141 Location: United Kingdom Thanked: 0 times
Posted: Wed Mar 29, 2006 7:37 pm Post Subject: |
Farl
dead easy this , lift board at sections where plumber has been , get a plain an shave off a sliver on each edge , these remedies mentioned only work as a stop gap , get it sorted , no trouble , a few hours on a sunday ...
Farl,
after sorting this your missus an you will be dead proud ,  |
stric
Joined: 05 Feb 2006 Posts: 77 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Thu Mar 30, 2006 8:40 am Post Subject: |
Personally I find that 90% of squeeking from a floor is from a nail, the boards rub up and down the nails causing the squeek, If your going to take the boards up try removing the nails first leaving the screws in. |
