DIYnot
Local | Network
   DIYnot > Forums
Local | Network
how do you use a roofing square
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
Author Message
Wildcelt
from United Kingdom
PostPosted: Tue Mar 28, 2006 5:29 pm Reply with quote
Hi all newbie here i was wondering how do you use a roofing square and it's convertion tables,i feel a bit embarrased as i did C+J for two years at college but i never moved on to roofing,any help guides or links would be great,because it baffles me?
Back to top
 Alert Moderators
mr_mike
from United Kingdom
Thanked: 1 time
PostPosted: Tue Mar 28, 2006 6:48 pm Reply with quote
Hello Wildcelt,
Being a red-faced 'Newbie' meself, and not being a roofer, I would let one of the real 'red back's' tell you how to use one, but (very briefly) they work roughly as follows :
To set out a roof, the rise of the roof is set on the narrow bit (the tongue) and the run of the rafter is set on the the wider bit (the blade), you'd then normally set the rise and run on the square by scaling down your measurements by ten. E.g. 3.5m becomes 350mm and so on. You join the readings on both scales using a batten or the like, and you get your various required lengths and angles from these readings.
The tables that are often on them give rafter lengths per metre run for 'standard' pitches.
That's as much as I know about roofing squares ! Over to one of the Pro's !
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1277 times
PostPosted: Tue Mar 28, 2006 7:08 pm Reply with quote
a scientific calculator and a 305mm de walt chop saw is what i use. oh and a tape measure........level...... hand saw......hammer...........nails....blah blah!
Back to top
 Alert Moderators
splinter
from Antarctica
Thanked: 2 times
PostPosted: Tue Mar 28, 2006 8:59 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
Roofing 4 560 Sat Oct 04, 2008 9:59 pm
Building a Workshop, Roofing advice and general hints!!! 29 3140 Mon Aug 09, 2010 3:03 pm
Roofing books 9 480 Sat Jan 16, 2010 3:40 pm
Fitting kitchen units to walls not square 7 680 Fri Nov 09, 2012 10:23 pm
Kitchen Worktop - walls not square 6 240 Sat Jun 02, 2012 9:45 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
