loft light (a different one)
amh
28 Mar 2006
Birmingham
hi
I need to find a neutral to connect a loft light into an existing single core system. i have identified a permanent live feed and what i though was a neutral to return to, but when switching the loft light on, a light in the bedroom comes on!! the loft light stays off
Sounds like you've tapped into the switch cable for that particular bedroom, :LOL:
Put it back how you found it, and find a ceiling rose for a bedroom, use the cables in there to get your loft light supply, :)
yes - you are probably right - the bedroom concerned has two way switching which would explain the junction box! :oops:
Thanks for the advice - i try again in the morning. ;)
oh yes - one other thing - it seems to be switch live setup - does this make any difference regarding the feed and neutral?
They are all "switch live setups" - single-pole switches are only ever supposed to be put in the live conductors.
And it is quite rare for 2-way switching to affect how ceiling roses are wired.
Look at the diagrams in For Reference - it's all explained there.....
:D Thanks for your comments and help - I have a working loft light that does nothing other than go on or off when asked!
Cheers all.
