MIDAS C.H noise
29 Mar 2006
Tyne and Wear
my midas combi boiler makes a hell of a noise when the C.H is put on. i have renewed the C.H pump but still a loud noise comes on only on the C.h side. can anyone help ??
There are noises and noises and without any indication of the kind of noise I cannot guess what yours is apart from perhaps a too slow flow causing kettling?
Be aware that your boiler must be approaching the age of 20 years and rather overdue for replacement.
I recall that there is another one still working in Stamford Hill !
Tony
thanks Tony. yeah i know its an old boiler but am getting married next year to a young boiler and cant afford the cash to spash out on a new combi. the noise iam hearing from it is like a "whooshing" or "pumping" affect. you can hear it in all the rooms in the house as if its going around the rooms.
is it possiable that it could be the automatic air vent ?
if it is "kettling" how do i repair this fault ?
thaks for the advice, iam a plumbing student of 6 months and this will help me in my course and undrstanding of plumbing.
cheers dom
dom2466 said:
... the noise iam hearing from it is like a "whooshing" or "pumping" affect. you can hear it in all the rooms in the house as if its going around the rooms...
is it possible that it could be the automatic air vent ?...
... this will help me in my course and understanding of plumbing.
What is the system pressure?
The noise is NOT caused by the auto-air vent, but the auto-air vent could be leaking water, leading to low system pressure and noise.
Open your text book and read the section on sealed systems. Understand that pressure is not flow. Understand that water expands when heated, and where this "extra" water goes in your system. Understand that gases are compressable, water is generally accepted to be non-compressable. Once you understand these things you are well on your way to repairing your own boiler. Failing that a trip to a boozer in Gateshead should put you in contact with someone - the Midas used to be made there.
thanks meldrew mate, the pressure is a 1 bar but when the heating is turned on is slowley goes up to around 3 bar .
tried to look on the net for a midas website that might be to help me with my problem but i cant find one. so maybe i might have a trip to gateshead for a pint to see if i can track down one of there empolyees and inteogate him .lol
cheers for the advice
hi wear gas, thing in the north east are generaly made of ahrder stuff so iam not surprised to hear midas are still going strong.
i have bleed the rads but havent changed over the thermocouple. will this stop the noise or just help with the kettling ??
P.S any plumbers in the north east looking for a helping hand ? been at college for around 5 months and wanting some hands on experiance. ive been working for the loacal water bourd for 8 yrs so am not "green as grass"
cheers for advive weargas
A "wooshing" noise implies air? Check that the pump has been vented and the AAV is working. ( AAV stands for Auto Air Vent and saves typing time when writing for people in the industry! )
The pressure increase is because the expansion vessel is failed or needs repressurising. Sort that out and vent the air and the problem will be fixed.
Look at the FAQ section on here for help.
Tony
cheers agile, whats AAV ?
i take a look at the pump agin and check the posting on here mate
tar dom
checked pump again/vented system/ stil the C.H noise still perstists. its like a pumping noise.
does anyone have any advice ?
or better, a myson website i could look at. cant find any on the web.
cheers dom
